Got the car up on stands for a couple of projects - fixing exhaust leaks and routing the heater cable to the hot air valves. Ran into a couple of problems that I hope you guys can help me out with.
When I pulled the heat exchangers, 3 of the 8 studs came out. I am thinking that I should go ahead and replace all 8, rather than just the 3. Do I even need to replace them? Any words of advice? Would blue loctite be a bad idea?
