QUOTE(motolitho @ Jun 26 2013, 09:03 AM)
Recently purchased a 1973 2.0 but I cannot confirm the engine. I am confused by the fact that there are no numbers in front of the oil tower OR where the 1.7 numbers should be. Has the large square airbox (seems to be intact fuel injection)... can anyone explain the 3 or 4 intake bolt thing to me? How do I tell what I have?
The 3 or 4 bolt intake manifold method of identification refers to the number of studs used to fasten the intake runners to the heads. All '72-'79 bus engines, all T4s, all 1.7s, and all 1.8s use 4 studs to secure the runners, 2.0 914s and 912Es use 3. Look below and on either side of the injectors for the nuts. Another easy thing to check is the location of the spark plugs. 2.0 914s and 912Es have the spark plugs mounted next to the intake runner mounting flanges, low on side of the tin. All other T4 engines have the access holes on the top of the tin.
By "airbox", I'm guessing you mean the air filter housing. The term "air box" is used to designate the mass air flow sensor on the 1.8 914s and 1.802.0 bus and T4 VWs and 912Es.
The Cap'n
