Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=394
877]Click to view attachmentClick to view attachmentClick to view attachment[attachmentid
=394881]Click to view attachmentClick to view attachmentClick to view attachment[attachme
ntid=394883]Click to view attachmentClick to view attachmentClick to view attachment[atta
chmentid=394889]Click to view attachment
Parts that I will not be using , went a different route. Post here that you will buy them , then send me a PM with your name and address and I will PM you my PayPal addy and pay using the " gift " pay . Time stamp in the pm will be first come first serve . Also PM with any questions and I will try my best to respond.
These parts also posted on the Bird board .
Jack
1. - 108mm early 911 Wheel stub 901.332.232.00 4 10mm X 1.5mm bolt 2 stud
$ 125.00 shipped SOLD
2. - 108mm early 901 Trans stub 901.332.209.15 4 10mm X 1.5mm bolt 2 stud
3. - 100mm Sc 911 Wheel stub 923.332.232.01 ( 42Cr is the only cast number )
6 bolt 8mm X 1.25mm - $125.00 shipped
4. - 23mm ATE master cylinder not sure of application , no numbers just 23 and
ATE cast on body - $50.00 shipped Sold
5. - 914 CV gaskets only have 3 - $10.00 shipped
6. - Fiberglass flares , again decided not to use , never mounted still in the box I
got them in ( 2005 ) - $175.00 shipped SOLD
7. - Precise SS Braid brake lines marked DOT Approved for EARLY 70-71 914 and
911/912 they only have the clip slot on one end not both , that's why they
early - YOU decide if you can use them - New in pack not removed - $30.00
shipped Sold
8. - Standard wheel studs - see pic 44m long - 20pcs - $ 30.00 shipped Sold
9. - Longer wheel studs - see pic 65.5mm long -20pcs - $ 55.00 shipped Sold
10. - Set of locks with original key plus an aftermarket key . These are driver
quality door handles and the frt trunk handle needs a repaint . They all work
good with the occasional wiggle needed - but they all are keyed to that one
key ( came off a '72 ) $ 100.00 shipped Sold
