trojanhorsepower
Jun 26 2013, 03:36 PM
I started my rotisserie build and thought I would share it.
So far I have an issues:
Will it matter if I weld the horizontal extension on top or underneath the part with the vertical section.
What do you guys think?
Here is where I am. I have cut the stands up and am ready to start cutting the expansion parts.
jimkelly
Jun 26 2013, 04:45 PM
trojanhorsepower
Jun 26 2013, 06:06 PM
Thanks JimKelly,
Those all look better than mine. I am going for fast and simple. I made a little more progress today. Anyone see reasons this will not work? My engine stands are 1.5" tubing not 2", so I had to make them work with what I had.
My verticals so far.
VaccaRabite
Jun 26 2013, 07:23 PM
I did it just a little different.
It was plenty strong!
Zach
3d914
Jun 26 2013, 09:10 PM
Did something similar. See
project thread for more details & material sizes.
mr914
Jun 27 2013, 12:12 AM
Made mine out of 2" tubing. Both heavy and thin wall
Vysoc
Jun 27 2013, 08:35 AM
I did mine exactly according to Blue Sky Motorsports Rotisserie specs. the only thing I would add is drill your holes in your rotation axle by placing the axles in the bearing, mark the perfect positions at 90,180,270 & 360 degrees with a small bit and then drill them. I did mine off the bench and they are not perfect but functional. Make sure your uprights are strong and straight.... you are holding up a very heavy item. I am on vacation now and do not have access to my pictures but can provide them in a week.
Also after looking at yours again, are you not going to add a 45 degree braces on both sides of the vertical center uprights?
Over engineering is always safer.
My .02 cents,
Vysoc
trojanhorsepower
Jun 27 2013, 06:02 PM
Thanks all for the pics and comments!
I will add some sort of 45 deg brace, just haven't gotten that far yet. Right now I need to finish the uprights and decide what wheels to use, then do the horizontals and then I can add braces.
trojanhorsepower
Jun 30 2013, 06:15 PM
Got a little more work done this weekend. I finished the second upright and got one side all together. A little primer to help cover up the ugly and wa la!
dlee6204
Jun 30 2013, 06:45 PM
Looks good man!
mr914
Jun 30 2013, 08:31 PM
Looks good
I used 8 500# D-rings from TSC or HF to be able to hold the car in the position I wanted. Afew rods/straps/cum alongs will hold the car in the position you want.
At one time, mine was balanced enough that I put my hand on it and it did a 180 on me in nothing flat. Now that there is more metal in it, I need to,hold it in position for the angle that I need .
Also, make a C collar for the ends of the rotisserie, unless you're tubing goes past your yokes, keeps the car from creeping out,
I did vertical and horizontal holes one one side for pinning in position, the other side I rotated the holes by 45 degrees for the same holding purpose
mr914
Looks good
Jon H.
Jul 1 2013, 08:30 AM
I used bolts to hold mine in place.
Click to view attachment Jon
trojanhorsepower
Jul 1 2013, 06:23 PM
Thanks All,
I got the other upright put together and primed tonight. I am planning on using the holes and pins that came with the engine stands; is there a reason that you guys see they won't work? I still need to fabricate my rear fixture to attach to the trans mounts. While I am mulling this over, I may go ahead and paint what I have so far.
trojanhorsepower
Jul 5 2013, 06:31 PM
Some people will stop at nothing to speed up their build!
trojanhorsepower
Jul 5 2013, 06:32 PM
I got my trans mount plates made today.
Vysoc
Jul 6 2013, 09:36 AM
trojanhorsepower
Jul 6 2013, 04:41 PM
Vysoc,
Thanks for posting your pictures.
I finished the metal work on the trans mount today, pics in that thread.
trojanhorsepower
Aug 17 2013, 06:38 PM
I am finally making some more progress. I go the fixtures both finished and the door braces in. I still need to weld up the hinges, but then it should be ready to go on the rotisserie.
trojanhorsepower
Sep 1 2013, 07:53 PM
Ta Da!!
dlee6204
Sep 1 2013, 07:56 PM
stugray
Sep 1 2013, 09:20 PM
You definitely want the piece that bridges those two stands together by the center legs.
Like in Vysoc's pics above.
It is not very stable the way you are showing it for moving it around the floor.
Stu
trojanhorsepower
Sep 2 2013, 04:01 PM
Connector bar installed and I have started striping the suspension.
