The CHT sensors are thermistors (negative coefficient)
You can certainly put the CHT in both ice water 0degC and boiling water 100degC and measure it with a resistance meter.
I did exactly that to determine that the CHTs I bought are thermistor type 2252.
That particular thermistor will read 7373 Ohms at 0C, 2252 Ohms at 25C, and 154 Ohms at 100C.
They will read an almost dead short (close to 0 Ohms) at 190C (300F).
That's why I determined that they are essentailly useless to determine if your engine is too hot (above ~290F).
However there is more than one type, so I dont know the values for any other than the one I bought.
The "chart" can be found here
http://www.veris.com/docs/support/faq/RTD-..._Z202030-0N.pdfOr serach for "Thermistor tables" "type 2252"
Stu
