Eric Taylor
Dec 1 2004, 06:01 PM
Hey all, I'm gona be testing vac leaks here in a little bit and I was wondering what fluid to use to test it. I thought it was break cleaner, but I also thought I heard that it was to flamable to use, I also heard water, but I also heard that dosn't do anything, so basically i'm curious as to what is a safe liquid to use when testing vac leaks?
Thanks,
Eric
TimT
Dec 1 2004, 07:21 PM
I use Berrymans Carb cleaner, Yo can use anything that will change the note of the engine when it finds a leak ether... gumout
ie something combustible
Bleyseng
Safe? Hell, I always have used starting fluid but use just alittle bit at a time instead of spraying the crap all over. If its a vacuum leak the rpms go up if you spray alot you get so much in the engine compartment the rpms go up anyway.
Geoff
redshift
Dec 1 2004, 07:27 PM
Yeah on the carb cleaner... if yu can fix a little extension straw thing in it, like WD-40 has, do it... and just a tap here... wait.... tap there... wait..
Instead of all that, you could put blue dye in the oil, and plug your pipes with a tater.. all you have to do is wait.
HAH!
M
qa1142
Dec 1 2004, 07:34 PM
I use propane torch (not lit). RPM increases and pin-point accuracy
