QUOTE(Harpo @ Jun 28 2013, 09:22 PM)
Sorry, this is a Raby 2270
I think you have to spell out T-Y-P-E F-O-U-R to these guys
Unless you are doing a front cooler just use 1/2".
I use Parker Push-Lok hose and fittings , no clamps. Everything else will be 3/8" NPT fittings
If you really want AN fittings then knock yourself out, I have bigger engines running on the Parker hose.
If you're doing a Full flow type one pump and cover you need a modified engine mount.
