I bought these when I thought I was going to convert to a six. They are cleaned up and zinc-coated. The 45mm studs look new. I have not used them. I have some spacers I will throw in the deal.
What are the stubs & trans flanges diameter 100 mm or 108 mm ? Looks to be 108 mm to me with the pin holes drilled and tapped ? LMK.
Mark Henry
Jul 2 2013, 03:11 PM
QUOTE(Luke M @ Jul 2 2013, 04:20 PM)
I agree, you should be clear on this, but if they are drilled 108mm you can use a late G50 CV's.
ww914
Jul 2 2013, 04:25 PM
QUOTE(Luke M @ Jul 2 2013, 01:20 PM)
They are 108mm in diameter. All holes are tapped.
A little background on these: I bought them as is from Jonathon at CPR Parts, who I believe said he got them from Eric Shea. Not that it matters, they are what they are.
Warren
Mark Henry
Jul 2 2013, 05:22 PM
QUOTE(ww914 @ Jul 2 2013, 06:25 PM)
Warren
This is the application and this is the best set up for a high HP, 5 bolt conversion.
This is a good deal and it's what I'm doing on my /6 conversion. Good luck with the sale.
Luke M
Jul 2 2013, 08:16 PM
I already have a set of 108 mm . I'm looking for the 100 mm trans flanges to pair with my 100 mm stub axles. They look good and should sell.
jaxdream
Jul 3 2013, 01:26 PM
QUOTE(Luke M @ Jul 2 2013, 06:16 PM)
The part number that you are looking for / need is 923.332.209.02 . Good luck ...
Jack
Luke M
Jul 4 2013, 07:05 AM
QUOTE(jaxdream @ Jul 3 2013, 12:26 PM)
Jack
Hi Jack,
Thanks for sharing the part #. I already have a set of 100 mm stubs and trans flanges. I'm looking for another pr of trans flanges for another project. I already have the hub/100 mm stubs.
