Well, as of today, I've decided to do an engine swap. (It's a surprise, don't ask what it is yet)
So, that means that I need to get rid of my current drivetrain. Absolutely everything will be included, as well as the fresh gearbox with new synchros and bearings. All you have to do is bolt everything in/together, and go.
So, here's the skinny on the engine:
It's a 2143 cc type 4 with a 74mm stroke crankshaft, and 96mm pistons and cylinders. It's a nice square combination for bore/stroke and is a really nice running motor. I have put maybe 25,000 miles on it since I built it, so there's PLENTY of life left in it. The motor burns no oil at all, and gets around 30mpg on the freeway depending on your driving style.
Engine specs are:
-Schneider Cams carb cam. (similar to the webcam 86)
-Brand new Febi lifters
-Chromoly pushrods
-911 swivel foot adjusters (real german ones)
-Solid rocker spacers from Jake Raby
-Cylinder heads were rebuilt by Adrian at HeadFlow Masters in Vista with new stainless valves, new guides and seats, and any cracks welded and remachined
-Chamber work and porting performed by Sean Molloy at SD Autosport
-74mm welded and reground original crankshaft.
-96mm pistons and cylinders from AA pistons. I went through 3 packages of P&C's and found the 4 pistons and cylinders that were all perfectly round and in spec.
-Lightened flyweel.
-9:1 compression ratio.
-Scat deep sump pan. (Increases oil capacity an extra 1.5 quarts)
-Headflow masters oil pressure relief valve (I run 30 psi oil pressure at idle when the oil is at 210 degree F)
-Melling cast iron high volume pump
Induction:
-Weber 40 IDF carbs, jetted perfectly for the motor using 32mm venturis. Jetting performed using a wideband AFR.
-CFR throttle linkage, perfect sync, all day, every day
-CB performance long intakes, port matched to heads.
-AN-6 fuel fittings and stainless braided lines throughout the engine bay.
-K&N air filters
Exhaust:
-Kerry Hunter header
-Stainless steel magnaflow muffler, exits on the passenger side. Sounds awesome, and not at all like a VW for those of you who would be concerned.
Ignition:
-Mallory Unilite, and MSD plug wires both purchased from Chris Foley at CFR.
-MSD 6AL rev limiting ignition box
-MSD blaster 2 high vibration coil
(Also included will be my Autometer sport comp tach that is wired directly to the MSD box. )
The engine tin was all Powder coated red, and has held up great.
The gearbox was rebuilt 2 years ago with new synchros and bearings where they needed to be replaced. It shifts great with fresh bushings.
I've done oil changes religiously every 3,000 miles, and "checked" on valves at the same time, however I think I've done actual valve adjustments at the 12,000 mile mark. I think 2 exhaust valves were maybe .001" loose..
Long story short, this is a 100% complete package for someone who wants to drop in a complete drivetrain and go, and go quickly. This motor pulls strong, and has run absolutely flawless for me over the past 2 years. It's been a daily driver, and most of the miles were all easy freeway miles.
Everything is still in my car, so if you're interested, come on over and drive it in the car. I'm certain you'll be impressed with the power and smoothness of the motor.
Looking to get $5000 for the entire package. It literally is a bolt in package for someone who wants a hot type 4, but doesn't want to go through the hassle of building a motor combo, and collecting all the parts, and then going through the process of tuning it. Dont be afraid to shoot me an offer for it, never hurts to ask.
Thanks, Ethan
