Now I'm wondering if I should have gone with larger venturis.
The engine is running really well with 51 idles, 110 mains and 145 air corr. jets.
Idle A/F is around 14:1
On the progression circuit (very light throttle) the A.F is about 16:1
Main circuit A/F is about 12.8:1 at least up to 5000 rpm in 4th gear.
However, in the transition range it gets a little rich, in the high tens and elevens.
This is a huge improvement from being so rich (low 9's) it coughed when it had the 175 A/C jets that were already in the carbs when I started.
I was expecting to deal with a lean transition, not rich, so I had to double check that there were unmodified F11 emulsion tubes.
The rich transition is why I think larger vents might work.
I'll try another size smaller a/c jets before calling it finished.
I've done all this tuning with the pump jets disabled.
If I hit the throttle hard it leans out to 13.6:1 briefly but recovers quickly.
There's a barely perceptible stutter on tip-in that disappears right away.
It won't take much of a boost from the pump jets to compensate.
