sean_v8_914
Jul 4 2013, 01:05 AM
Joel has decided to sell Sweat Pea. the pea was created by Jerry M, a member here. Joel bought the car and we finished the details. we used lock washers, locktite and all the stuff that makes a car stay together. no duct tape, chewing gum or improvised fasteners. proper fasteners is my pet peeve/ fetish
sean_v8_914
Jul 4 2013, 01:08 AM
how do yous guys add long strings of images here? I can only get 2 at a time.
sean_v8_914
Jul 4 2013, 01:11 AM
just add fuel. you dont even have to wax it for a long time.
sean_v8_914
Jul 4 2013, 01:13 AM
pizza trunk
sean_v8_914
Jul 4 2013, 01:19 AM
here is a partial list. there are many more details to list
Suspension brakes wheel specs:
Front suspension and brakes: 911 T
Front suspension torsion bars: 18mm 911 type, stock red
Front suspension sway bar: 914/4 type 15mm stock
Front suspension bushings: stock rubber
Front suspension strut inserts: Bilstein sport yellow new
Rear suspension springs: 100 lbs Weltmeister SP100 black
Rear suspension shocks: Bilstein sport yellow new
Rear suspension sway bar: none
Rear suspension bushings: stock rubber
Wheels: Fuchs 16 x 6 polished lip, satin black center
Tires: BF Goodrich 205/ 50 R16
Master cylinder: ATE 19mm, new
Brake lines: ATE rubber, new
Engine and drive train specs
Pistons: 96mm flat top 8.5 to 1 compression
Crank shaft: 2.0 Porsche 71mm
Connecting rods: 2.0 Porsche
Cam shaft: webcam XXX custom grind
Cylinder heads: 2.0 Porsche 3 stud, rebuilt
Induction: New dual Weber 40 IDF carburetors, center pull linkage heim joints, Teflon lined Terry cable
Ignition: Bosch mechanical advance distributor with electronic trigger, Bosch blue coil BERU spark plug wires
Exhaust: SSI stainless steel heat exchangers, Bursch merged tuned 4-2-2-1 collector
Engine case: 1.5 quart low profile external sump
Fuel pump: front mounted Carter rotary type powered by factory fuel power circuit
Fuel lines: BMW 8mm CA ethanol fuel rating
Oil: Brad Penn 20-50
Transaxle: rebuilt 901 side shift conversion, new shift linkage and bushings, 90wt hypoid Valvoline VR-1
Rear transaxle mounts: upgraded 911 sport mounts
Starter motor: upgraded IMI Hi Torque gear driven with high current external solenoid
Interior specs
Morph interior panels
914rubber.com seals by Mark whitesel
pedal cluster by Bruce Stone
Steering wheel: 3 spoke Dino
Floor mats: Lloyds black with green 914 monogram
Seats: black with custom cloth center inserts, adjustable passenger seat
Seat belts: new retractable type
Entertainment: new stereo and Baupunkt speakers with IPOD and MP3 player
Door panels: custom 911 RS type
Pedal cluster: rebuilt, zinc plated, powder coated, silica-bronze bushing kit
Exterior, paint and body specs
Color: original L63k Willow green monochrome paint scheme
Side marker delete, antenna delete
Fresh weather strips rubber, door seals, bumper tops, body gaskets
New windsheild
Trophies, awards, featured on display, other
2011 San Diego International Auto Show “History of Porsche” Display, 3rd Place in Division 2011 PCA Zone 8 Concours d’ Elegance, Best Early German entry 2011 North Park Historical Society Auto Show, 1st Place in Division 2012 PCA Zone 8 Concours d’ Elegance, Currently registered as a CA Historic Vehicle.
124,000 original miles, “Full Restoration Driver” completed in 2011, less than 2000 mi since completion
sean_v8_914
Jul 4 2013, 01:27 AM
wires have grommets. cables are routed out of harms way and secure. cables have strain reliefs and chafing guards. fuel lines are routed outboard of the engine. fuel line junctions are below deck and away from the cooling fan and exhaust. cleaned relay board, chassis ground points, fuses, contacts and light sockets.
sean_v8_914
Jul 4 2013, 01:31 AM
new 2056 with new carbs and perfectly synchronized center pull linkage is coupled to freshly built 901 side shift gear box
sean_v8_914
Jul 4 2013, 01:33 AM
no rubs here
sean_v8_914
Jul 4 2013, 01:37 AM
drives better than a new 914. Dr Porsche would be proud.
sean_v8_914
Jul 4 2013, 01:40 AM
I should have wiped down the belly gear before I took the pics.
no hell in this hole
sean_v8_914
Jul 4 2013, 01:44 AM
Morph, Whitesell, Stone, camp914!
sean_v8_914
Jul 4 2013, 01:46 AM
green!
orthobiz
Jul 4 2013, 09:17 PM
I need to stop looking at this car. Stop...looking...must...resist...
Seriously, this highly modded greenie is cool as hell!!!
Paul
BajaXJ92
Jul 4 2013, 11:30 PM
orthobiz
Jul 5 2013, 05:40 AM
Can you show a closeup of the dash? I'm curious exactly how the color matching looks close up.
Thanks,
Paul
Niklas
Jul 5 2013, 05:44 AM
Nice!
Maybe it should go to Sweden to me.... to me
Anyone know how to arrange the fright to Sweden ?
Is it the original colour ?
Niklas
orthobiz
Jul 5 2013, 06:05 AM
QUOTE(Niklas @ Jul 5 2013, 07:44 AM)
Nice!
Niklas
Yes original...
No Sweden!!!
Just kidding...
Paul
sean_v8_914
Jul 5 2013, 09:18 AM
this is the original color, l63k willow green.
non appearance group 914s had body color bumpers and no sail panel trim
sean_v8_914
Jul 5 2013, 09:28 AM
i am installing new retractable seat belts with inertia reels
there is no such thing as a 100% rust free 40 year old car but The sweet Pea is about as rust free as you can find anywhere
this image shows some surface rust. i have been thinking about finishing off this area if it does not sell. more green i think. i just dont want to disassemble since everything is so dialed in.
it takes less time to assemble than it does to dial in the details that make for a great driving experience
sean_v8_914
Jul 5 2013, 09:31 AM
the red stuff is 3m flange sealant. it follows the expansion and contraction difference between steel and aluminum. stays soft but impervious to automotive fluids. very expensive but never leaks
orthobiz
Jul 5 2013, 11:37 AM
I'd say the car is rust free.
Paul
sean_v8_914
Jul 5 2013, 12:03 PM
rust free. if you buy the Pea, I will not charge you for that rust, it's included free
orthobiz
Jul 5 2013, 02:59 PM
Rear brakes and rotors? 914-6 style?
Paul
sean_v8_914
Jul 6 2013, 09:46 AM
early 914 hubs drilled for 5 lug. close up in post #9
sean_v8_914
Jul 10 2013, 01:25 PM
various car shows
sean_v8_914
Jul 10 2013, 01:28 PM
international auto show porsche display in san diego
sean_v8_914
Jul 11 2013, 03:26 PM
Morph in the vendor section made teh RS door panels and teh speaker pods. i think Mark whitesell of 914rubber.com sells his stuff now. 914rubber.com provided teh rubber seals
sean_v8_914
Jul 20 2013, 11:52 AM
i promise to wipe the drool marks off before you buy it. i store it on my lift just to keep me honest.
sean_v8_914
Jul 21 2013, 12:25 PM
its official, i have joined the 21st century
https://vimeo.com/70730867this is my first video on the web. where's my gold statue ?
sean_v8_914
Jul 21 2013, 12:30 PM
photo shop help...
could someone please change the roof, rockers and valances to black. i'm curious.
sean_v8_914
Jul 24 2013, 07:54 AM
sean_v8_914
Jul 24 2013, 08:00 AM
johnnie5
Jul 24 2013, 12:01 PM
Hey Sean, I didn't see a price... how many green backs for the Sweet Pea?
orthobiz
Jul 24 2013, 02:41 PM
QUOTE(johnnie5 @ Jul 24 2013, 02:01 PM)
19995, it's in the original post.
Paul
sean_v8_914
Jul 29 2013, 12:20 AM
price drop
how much would it cost to build?
how long would it take to build?
how long will it take you to sort it out to where you could jump in and drive a few days away from home in confidence.
san diego to sturgis, hmmm...
sean_v8_914
Jul 29 2013, 12:21 AM
$18,7
sean_v8_914
Aug 14 2013, 07:53 AM
5 quarts of fresh Brad Penn
x-faktory
Aug 16 2013, 08:18 PM
That beauty is coming to a garage near me soon...........I'm planning my fly in-drive out road trip now!!!!!
regards,
Al
sixnotfour
Aug 16 2013, 08:28 PM
WOW , Al Great 914...have fun with it..Jeff
orthobiz
Aug 17 2013, 08:13 AM
Congrats, Al. Maybe, just maybe, I can stop thinking about this car now!
Paul
sean_v8_914
Aug 17 2013, 09:01 AM
she looks even better in person.
x-faktory
Aug 17 2013, 09:18 AM
QUOTE(sixnotfour @ Aug 16 2013, 07:28 PM)
Jeff,
This is going to be nothing but fun. i'll see you on the road.
regards,
al
x-faktory
Aug 17 2013, 09:32 AM
QUOTE(sean_v8_914 @ Aug 17 2013, 08:01 AM)
Sean and Paul,
I could not get this 914 out of my head either and the more of them that I looked at, and I looked at some very tasty cars.....this one stood out. It looks right to my eye and it is apparent that the caretakers were committed to making it a beautiful, solid 914. I'm looking forward to meeting up w/Joel in San Diego and then heading up the coast. What could be better?
This is my first 914, but i have been a 911 owner for many years and participate quite a bit on the Pelican Parts (al lkosmal), Early S (xfaktory) and RGruppe forums. I look forward to going down that slippery slope with this one, learning from the collected knowledge/wisdom of the 914 World, and eventually contributing.
regards,
Al
PS: here's a link to my YouTube Channel..it will show you some of my projects, etc.
http://www.youtube.com/user/koz77911
sean_v8_914
Aug 17 2013, 11:27 AM
the Pea is one of my all time favorites also.
sixnotfour
Aug 23 2013, 07:02 PM
wow GREAT START,,, Al, enjoy the mid engine....
x-faktory
Aug 23 2013, 11:09 PM
Stay tuned for road trip pix..........
x-faktory
Aug 27 2013, 09:27 AM
