Full Version: SIX engine tin- question
Trekkor
About ready to do this.
Is it easier to get the motor in and then install the tin or put it on first?
Do the tabs that attatch to the sides of the motor bend above the tin or under?
Thanks
KT
sixnotfour
Tin on first , when take the motor back out the side pieces are tight on the inner pivot bolt. carefull , going in is pretty easy.
What sheetmetal do you have? factory, repo, root,other ?
Red your your post again , Tabs bend down Jeff
