I have two front and two rear used sway bars for sale;
1. Stock front 15mm sway bar $150 shipped. The bar bushings are in good shape, but will need new drop link bushings
2. Welteister front 22mm sway bar $200 shipped. In excellent condition with tight bushings, and shows bery little wear. SOLD!!!!
3. Stock 16mm rear sway bar $175 shipped. With the shock bolts. Light corrosion on the ball where the drop links mount. Should clean up well. Will need new bushings for the bar and the drop links. I will need your old shock bolts in return SOLD!!!!
4. Unknown after market rear sway bar appears to be 17mm $75 shipped. The bushings are in good shape and are tight. I wouldn't say the system employed to mount the drop links is the greatest, but it works. Will need some new hardware.
All shipping is included for the lower 48, willing to ship international, but will quote you the amount.
Thank you,
Matt
#1 Stock front
#2 Weltmeister front
#3 Stock rear
#4 After market rear
