QUOTE(r_towle @ Jul 10 2013, 09:28 AM)
two bolts in one transmission flange, then slip a bar between the bolts and lay it at an angle on the ground to hold that flange still.
Two bolts in the other flange, then use that flange with the car in 4th or 5th gear turning it backwards, that will turn the motor forwards.
DO NOT use the fan hub bolt...it could easily break off.
rich
This works but you said to turn the flange backwards and the engine goes forward. I turn mine forward and the rotor button goes clockwise....forward right?
I read in one of the manuals about valve adjustment and they go backwards so you can get #1 then #2 then put the rocker cover back on.
