BS Chairman
Jul 10 2013, 05:50 PM
FS misc 914 parts - Revised prices
Newest Items
Late Dash - VGC has one delaminiation at the corner of the left side gauge pod - $250 See Below
Rocker Panels - See Below
Windsheild gasket- See Below
Blasted and painted trailing arms w/hubs- See Below
Many newer items listed below.
1.8 Engine relays $20 = SOLD
1.8 FI computer $25 was running when switched to carbs
L&R A Pillar cover w/plugs $25
Splash pan for under car. Blasted, painted, has some pits, tabs good $50
Door switch with gasket $5
Center/3rd Seat - Plastic tray decent, cracked hole. Center pad is solid, vinyl good $55
Early gauge set with silver buttons. Trip ODO unknown. $100
Headlight Motor Covers (pair) $20 no cracks
Hood cable and pull - chipped paint - no key = $5
Ignition cylinder lock w/key we think it's late 71-73 - $5
Side marker Lens, crack on top - free with other purchase
Speaker box - No cracks $20 SOLD
New Speedo Cable $50 SOLD
Side Targa Strip, the ones on the top, not the rear strips - so/so condition $5
Defroster vents -later cars w/center defrost $10
Will give discount for multiple items
All items are plus shipping
I take PayPal
KENNY
Jul 10 2013, 07:11 PM
I will take speaker
BS Chairman
Jul 10 2013, 07:56 PM
Kenny send me a PM for paypal address
Gary
jim_hoyland
Jul 11 2013, 07:07 AM
I'll buy the hood pull/ cable. PM sent
JeffBowlsby
Jul 11 2013, 01:20 PM
I will take this assembly. Total shipped to 94583 and payment details please. email or PM me.
BS Chairman
Jul 11 2013, 05:59 PM
Steering Wheels 2 types - BOTH SOLD and SHIPPED
Wheel 1 - Later model $65
Wheel 2 - 70-71 - uses long horn button feeler/extension - $65
Both wheels have minor nicks/scratches. No chunks or gouges missing
Horn pads in good/VGC
BS Chairman
Jul 11 2013, 06:02 PM
A Arms and cross member - Just blasted
Selling for cost of blasting plus $10
A Arms - $60 pair - Sold - Shipping 9/5
Cross Member $35 - Sold - Shipping 9/5
Can put a light primer or paint (rattle can) on prior to ship.
BS Chairman
Jul 11 2013, 06:04 PM
MPC wire harness with unknown FI box
Harness has good soft boots, and is not brittle
FI box is included NC
$125 plus shipping
BS Chairman
Jul 11 2013, 06:13 PM
Misc Items
Front Turn signal housing with crappy lens. The electrical contacts on this housing is good and the inside finish of the reflector is in great shape. Exterior has undercoating and road grime - $75
1 Pair Early window cranks - chrome has some pitting - $30 pair
Early metal interior door pull with plastic insert $25
Left Side Tail Light housing - $25 Exterior housing has no cracks or heat blisters - has overspray on interior reflectors. Stud from tailight broken off and left in housing. Purchaser will have to remove knob/stud
Rear Struts and Springs - NOT KONI or BILSTEIN - No manufacturer marking on strut. SOLD
BS Chairman
Jul 11 2013, 06:18 PM
CV Joints, Axles, Boots and stub axle.
What can I say
Blasted and painted stub axle and half shaft
New boots
CV joints are tight and grease free
Pulled one apart to inspect - see photo
Other one was not opened up for inspection
Click on photo for larger view
$225 per side
$375 for pair
Plus shipping
BS Chairman
Jul 13 2013, 04:13 PM
Rear targa strip, minor scratches no gouges. Not the best, but a decent set $35 pair ---Sold
Front door seal strips - $20
Early mirror $35 - Decent housing w/gasket. Mirror bad Sold
All plus shipping
billh1963
Jul 13 2013, 07:31 PM
I'll take the mirror
BS Chairman
Jul 25 2013, 03:07 PM
From top left, down and then to right
Late model Jack Straps, good rubber - $10 pair - SOLD
(4) 2.0 wheel caps, crusty, dinged, $15 pair
(2) headlight motor actuator screws $10 pair
Side Shifter Transmission Coupler $30
Rear Trunk Top Latch Mechanism (plastic spacer has wear spot $25
(2) round relays - $10 each
Shock Rubber (4) , spacer (2) and 2 caps - $10 Set
Door stay $15
Koni Adjustable shock adjustment knob - $10
Rocker Panel Jack point covers $10 pair
Cigarette Lighter $30 - Bezel is so so
Bag of 5 Fllywheel bolts, Torqued once $10
Rubber covers for rear shock tower $12 pair
Plus shiping
BS Chairman
Jul 25 2013, 03:17 PM
7 25 bag B
Late Door Vent Plug with filter $5
L&R vent window gasket. Used but in good shape $20 pair
Door handle Base - Flapper handle broken, Stud Broken, but could be drilled and tapped- No Keys $5
Early rear targa handle latch cover - Metal $20
MOMO Horn Pad - Unknown Model - $5 plus shipping Sold
Gold annodized heater tube clamps - $5 each VGC
BS Chairman
Jul 25 2013, 03:22 PM
Chrome hub caps for early car - Decent chrome, rusting on back $5 plus shipping
Long Lug Bolts, set of 16, needs blasting/refinishing/cleaning $25 set SOLD
SS Brake Lines - Unopened $30 set
2 NEW Sets front Brake Pads - $40 pair
BS Chairman
Jul 25 2013, 04:16 PM
7 25 bag C
Nuts for Tail light lens, set 6 - $5
Rear Trunk Light, Good condition, no overspray $15
Rear Targa Latch cover - Late style, plastic $10 set
Drivers side targa latch- Works, needs cosmetic - $20
Defrost Button and cover - $20
Metal 914 -- Fair shape, no broken pin - $20
BS Chairman
Jul 25 2013, 04:22 PM
7/25 Photo D
Rubber cover for headlight motor - good rubber $15
Door stays w/actuators $25 each
SOLDLate 914 tool kit. $25
New Late style heater blower air splitter - Aftermarket, unopened package $25---Sold
BS Chairman
Jul 25 2013, 04:27 PM
New Bosch Cold Start Valve - MPC $30-----Sold
SEM PCA Hood/Grill badge, one stud broken off - $15 = SOLD
Front Turn Lens - Good Shape, no crazing or scratches $10
All Plus shipping
BS Chairman
Jul 25 2013, 04:33 PM
This one is a little weird, but, is it better to show your concourse car with a broken correct part or a new reproduction part?
1970 Hella backlight, with Chrome Outline and white switch $20
Yes, it is broken and someone did try to repair it.
You be the answer to this question....
Steve Snyder
Jul 25 2013, 04:46 PM
Dibs on the late tool kit & lug bolts, PM sent.
BS Chairman
Jul 25 2013, 05:30 PM
Tool Kit Sold and shipped
Lug bolts pending Sold and shipped
BS Chairman
Aug 2 2013, 12:54 PM
Have many more parts in boxes from my 20+ year habit.
If there is something you need, PM me and I may have it.
Will be listing more in the next couple of weeks.
BS Chairman
Aug 15 2013, 09:22 AM
Firstcar
Aug 15 2013, 09:26 PM
I'll take the SEM badge. PM sent.
Aug 15 2013, 09:31 PM
let me know if you have any more oem steering wheels. thanks, mark
BS Chairman
Aug 30 2013, 10:57 AM
Open to offers
Inventory manager, tells me she wants some of her shelf space back....
bcheney
Aug 30 2013, 01:47 PM
QUOTE(BS Chairman @ Jul 25 2013, 05:07 PM)
Door stay $15
Plus shiping
I'll take...Late model Jack Straps, good rubber - $10 pair
Will PM my address.
BS Chairman
Sep 3 2013, 01:18 PM
Rubber Seal never used $150
This is the seal at the top of the windshield with corner blocks to the section that seal at the front of the triabgle door glass.
Rear Trailing arms, 4 bolt Hubs and bearing Caps. Done in 2 part epoxy paint. $150
Pair of rear wheel bearings $160
BS Chairman
Sep 3 2013, 01:20 PM
Steel Rocker Panels Straight and no rust, Does have a few paint scratches- $280
Plus shipping.
BS Chairman
Sep 3 2013, 01:32 PM
Late Dash - VGC has one delaminiation at the corner of the left side gauge pod - $250 Plus Shipping
914jims
Sep 17 2013, 12:32 AM
Do you still have the dash ? If so any better pictures of the delaminated section? thanks, Jim
pilothyer
Sep 17 2013, 02:55 PM
QUOTE(BS Chairman @ Sep 3 2013, 02:18 PM)
Is this an original Porsche part or aftermarket? Very interested......Jerry
pilothyer
Sep 18 2013, 11:55 AM
I also wnat the: L&R vent window gasket. Used but in good shape $20 pair
Jerry
