tornik550
Jul 10 2013, 08:04 PM
For the past year, I have been fighting my innovate lc1 setup. It would work under certain circumstances. I never really trusted the readings. Everything was setup properly and calibrated properly. I just got fed up and got an AEM setup. Installed it, started right up. Turns out that my innovate readings were really inaccurate. I was having a super difficult time tuning my carbs cause I was getting strange readings. Now with the AEM, it turns out that my carbs are pretty close to where they should be
Very please with the AEM setup.
Trekkor
Jul 10 2013, 08:11 PM
Same one I use.
Nice set-up.
KT
brant
Jul 10 2013, 11:48 PM
I've checked my innovate system with an air injected professional dyno jet system. 3 separate years. It's dead accurate.
jim_hoyland
Jul 11 2013, 07:03 AM
What is AEM ? Have a link ?
tornik550
Jul 11 2013, 07:06 AM
QUOTE(jim_hoyland @ Jul 11 2013, 09:03 AM)
http://www.aemelectronics.com/wideband-air...-fuel-gauge-25/I got mine on ebay new for $155 shipped.
Mark Henry
Jul 11 2013, 07:16 AM
How did you mount it?
Was the harness long enough?
iamchappy
Jul 11 2013, 07:36 AM
I may have to convert my LC-1 has been acting up..
tornik550
Jul 11 2013, 07:54 AM
QUOTE(Mark Henry @ Jul 11 2013, 09:16 AM)
I have a plate in the dash with holes cut out for gauges. I took the innovate gauge and replaced with the AEM. The stock harness was long enough. I even had a lot of slack. My headers exit on the passenger side. I ran the wire through the tunnel then over the engine, out the rear tin then to the bung behind th epassenger cv joint.
worn
Jul 11 2013, 10:06 AM
QUOTE(Mark Henry @ Jul 11 2013, 05:16 AM)
I had extra wire. My gauge is mounted on the floor (very bad spot) because I already have a rubber 3 gauge pod full under the dash. It wired in great and I bundled the left over wire for when I make my triple or quad gauge. Then I will move it up to replace the oil pressure and volt meter. The bung went in without a problem and I routed the wire along the clutch cable jacket.
I am making headway on dialing in the MPS for the 2056 with higher compression. Without the gauge it would be all over.
Mark Henry
Jul 11 2013, 11:00 AM
QUOTE(tornik550 @ Jul 11 2013, 09:54 AM)
Are you running a console?
I have the same question in at PLX, also asked if it's OK to cut and splice, but no reply so far.
I don't have a console and want to do the ashtray mount trick, just wondering if you had enough slack to run the loop to the front of the foot well and back up into the dash.
I'll be running a /6 so it would have to reach right back to the muffler area.
Just wondering if it has enough harness?
Mark Henry
Jul 11 2013, 11:04 AM
Sorry I did get a reply from PLX... just was hard to open
Sun, Jul 7 2013 7:03AM
Hi
I have a Porsche 914 and VW bug, your harness is too short, I see you also have a 10' harness but to hide the cable this is also too short. Do you sell and extension cable or is it OK for me to cut and splice in my own extension cable.
Thanks.
BTW this will also be to short for the 911 guys as well.
Thanks Mark
Mon, Jul 8 2013 4:36PM - staff
We do not offer an extension cable, however you shouldn't have any issues extending the harness. Just make certain that the wires are connected in the same place, and you have a solid solder job. You can purchase an additional harness here:
http://plxdevices.com/product_info.php?id=ACCEWBHARNESS
worn
Jul 11 2013, 11:12 AM
QUOTE(Mark Henry @ Jul 11 2013, 09:00 AM)
I hope to put one on a 6 someday too. I don't have a console, and I tested the wire to see if it would run the length and back up the underside. Yes, it does. I may do the ashtray too. The O2 sensor is at the extreme rear of the car, so it oughta work. I went with the cute turquoise color because it reminded me of Stewart Warner gauge lights. Why they put all the trouble into this I am not sure. Guess matching is nice.
tornik550
Jul 11 2013, 11:17 AM
I have a plate in the dash where the radio goes. I just mounted the gauge there. I ran the wire down behind the front firewall, through the tunnel, over the engine, out the back of the engine and too the exhaust at the right rear of the car. That was all with the stock harness. I also had some slack left over. I contacted AEM about splicing however I have not heard back.
iamchappy
Jul 11 2013, 11:56 AM
I removed the sensor today, cleaned it up and blew it out before doing a free air calibration. the Lc-1 did work better today but pegs at 18 for a few seconds in between shifts when on boost, before returning to normal operation. It could be because of flames shooting out my tail pipe but dont know for sure if flames are, may need to hook up the Go-Pro to check on that......
worn
Jul 11 2013, 12:58 PM
QUOTE(iamchappy @ Jul 11 2013, 09:56 AM)
Not all of can boast flames from boost I am afraid. Wish I could...
Mark Henry
Jul 11 2013, 01:12 PM
QUOTE(iamchappy @ Jul 11 2013, 01:56 PM)
All that matters with any wideband is the reading under load.
tornik550
Jul 11 2013, 03:22 PM
I just received a response from AEM about splicing the wires. They said it is ok to add 2-3 feet however not much more than that. Of coarse, also make sure the wires are well crimped.
Justinp71
Sep 23 2013, 07:54 PM
Its been a couple months, any updates?
I like the AEM unit and all the tuners seem to rave about it. I also really like the colored LED's so you can see your AFR without having to stare at the gauge while your flooring it! I think I'll be ordering one...
tornik550
Sep 23 2013, 08:23 PM
QUOTE(Justinp71 @ Sep 23 2013, 09:54 PM)
I have been using it for the past few months. I highly recommend it. The air fuel gauge is no longer something that I think about cause it works perfectly without any problems. BUY ONE!!!
DBCooper
Sep 23 2013, 08:32 PM
I had an Innovate LC1 that crapped out after a month in the car, and I also replaced it with the AEG, which has worked as advertised. A friend has just strongly recommended the new Innovate LC2, which I intend to try. Supposed to cure the problems of the LC1 and add some features beyond the AEG. I'm interested enough to give it a try and will let you know how it works out.
Justinp71
Sep 23 2013, 08:42 PM
Is the AEM cable long enough? Sounds like everyone just runs it under the motor, into the cable tunnel and up the front firewall? Does anyone know if its long enough to do the drivers side pillar gauge pod?
tornik550
Sep 23 2013, 08:52 PM
QUOTE(Justinp71 @ Sep 23 2013, 10:42 PM)
My o2 sender is mounted on the passenger side rear of the car, It goes through the tin, around the passenger side of the engine, through the firewall, through the tunnel then up to the center under the ashtray. I had a lot of extra wire. I think you could reach a pillar however it is ok to splice extra wire in if needed.
worn
Sep 24 2013, 11:39 AM
QUOTE(Justinp71 @ Sep 23 2013, 06:42 PM)
I had a lot of extra wire running up the front fire wall and then back to a floor mount (which is a bad spot). I ran up the firewall for eventual mounting up with the other gauges. You should be fine.
Justinp71
Sep 28 2013, 08:41 AM
Got the gauge yesterday, install time...
How do you guys go through the rear firewall? Drill a new hole or fit it with the wiring harness (seems tight)?
Justinp71
Sep 29 2013, 05:43 PM
Got it in, just realized there is a nice hole in the firewall for the speedo cable you can stick the AEM cable through and route it with the factory wiring harness.
I do agree AEM is much better so far than the Innovate, I had an Innovate LM1 on my other car. It was much more difficult to install and more finicky overall, this one has been working very well so far and they are super cheap on ebay right now.
GeorgeRud
Sep 30 2013, 09:09 AM
What size is the gauge (2 1/8")? Does it fit in the center console location?
Java2570
Sep 30 2013, 10:56 AM
It's 52mm (2 1/16") so it's a pretty good fit in the console. I installed mine about 3 weeks ago and it works very well so far. I found the wiring installation very easy through the center tunnel and I too had
a hole that was a perfect fit for the connector to make it through the firewall. Very happy with the AEM!
