QUOTE(Teknon @ Dec 4 2004, 08:40 AM)
My back window was flapping around, so I picked up another window with a defoster in it. Does anyone have a harness or a schematic for it's install.
no harness, but the install is easy.
you'll need:
- one round black relay just like the others on your relay board.
- a few feet of wires. the original wires are "Yellow/Red" and "Green".
when looking at your relay board,
- the relay goes into the socket closest to the front of the car.
- the 2 wires are connected to a 2-prong connector just in front of the 2 fuses.
the yellow/red wire goes onto the left prong, the green wire goes onto the right prong.
if you have a haynes manual (which you should!) go to page 147 for a schematic of the relay board. the defrogger wireing is the same through all the years.
in the haynes manual, the defrogger relay is #52, the wire connector is just in front of that.
i doesn't look like the main harness of our cars has a wire for the dash switch build in, so you would have to figure out how the switch was included in that circuit.
Andy
