QUOTE(ThePaintedMan @ Jul 16 2013, 09:29 PM)
QUOTE(bdstone914 @ Jul 16 2013, 10:08 PM)
I have them if you do not find one closer. You might call your local VW or Porsche dealer and see what it costs. Many common bolts are only a couple of $$.
You do not need to pry on the hub. One hit with a hammer usually get it off. It is on a cone shaped nose so it only needs to be broken loose.
Bruce
Thanks Bruce,
Mblizzard has one and is sending me one when he can. Thanks for the tip on the hub. Hammering on the end of the crank is okay... I mean the shock won't hurt anything?
You are directing the force away from the crank. I was showed the trick by a very experienced engine builder. One pop and it was off.
Use a long blunt punch. Do not hit directly on the hub with a hammer.
