OK, here is the scoop...I am running on 2 cylinders...
New motor
oil leaks to be fixed
before I pull the engine, i want to dial in the fuel injection(megasquirt)
OK, I am running twin throttle bodies, on 3/4 side, when I cover the stack, the motor bogs down and will die. When I cover the 1/2 side, nothing.
I have swapped the injector wires, no change
I have swapped the plug wires, no change
I have an air flow meter, no change when I rev it up.
I am guessing stuck exhaust valves? or bent intake push rods...
I can't find my compression gage right now, so I need some thoughts on what to do next...
Perhaps a poll on what is causing this...
anyway, I have more power on 2 cylinders than I used to have on 4...
I do have fuel being injected to 1/2, I do have spark. Fuel is determined by the white cloud in the intakes, spark by the timing light.
I am thinking that I must have no compression for this type of thing to occure..got to find my gage....
Well lets have it...
103 by 80, large valve motor...163/86b cam ceramic lifters..nickies...figure it out and I will buy you a
thanks, herb
