qa1142
Dec 4 2004, 05:22 PM
Damn, likely tightened 30 years ago!
Impact driver? big ass screw driver? This old motor is too greasy to risk heat
i don't want to leave 1/2 in the case.
Suggestions?
Mueller
Dec 4 2004, 05:28 PM
QUOTE(qa1142 @ Dec 4 2004, 04:22 PM)
Suggestions?
yep, you answered your own question
I have a large screwdriver that I can put another screwdriver thru the handle for some extra torque....
good luck
Rhodes71/914
Dec 4 2004, 05:34 PM
Biggest screwdriver you can fit in the slot, maybe a little penatrant (sp)
Eric_Shea
Dec 4 2004, 05:36 PM
MAP torch. Works everytime. Everytime.
eeyore
Use the largest craftsman screwdrive and BFH.
Stripped bolt removers work well too.
http://www.sears.com/sr/javasr/product.do?...pid=00952166000
ChrisFoley
Try tightening them just a little before loosening them. This often breaks the corrosion bond and makes it easier to remove them. The same applies to brake line fittings.
914werke
Dec 4 2004, 05:37 PM
Very carefully
TheCabinetmaker
Dec 4 2004, 05:41 PM
I use a 1/2" drive, hand held impact screwdriver with the largest tip I can get in the screw. It too, works everytime. Like Chris said, try tightening it first.
URY914
Dec 4 2004, 05:46 PM
I have a big ass screwdriver that has a hex section on the shaft right under the handle. I think it is made by SK Tools. You can put a box end wrench on it and really put some force behind it.
P
morgan
Dec 4 2004, 06:10 PM
YA, Be carefull how you say cheese heads Wisconsin you know!!!
JOHN
Dave-O
Dec 4 2004, 06:56 PM
Who said cheeseheads!!
GO PACK GO!
Doug Leggins
Dec 4 2004, 07:06 PM
Impact screwdriver works pretty well.
I also like a 3/8" drive screwdriver tool that I have. Can get alot of torque easy with this tool and a 3/8" ratchet.
tracks914
Dec 4 2004, 07:32 PM
QUOTE(vsg914 @ Dec 4 2004, 03:41 PM)
This is the best way to get them off. Tightening first only breaks the head off too many times. Heat damages wires and rubber. Impact screwdrivers are a must for any workshop and only cost about $10.
Dave_Darling
Dec 6 2004, 12:09 AM
Just make sure the tip is the correct size for the slot in the screw.
The only screwdriver that I could find with a tip that was the right size was the largest one that my local Sears stocked. It's a really big mother... Not easy to use in the 914's engine bay, but not so bad when the engine is out.
I replaced all the engine tin screws that I could with Allen-head screws. Much easier to install and remove!!
--DD
Kevin@ojai.net
Dec 6 2004, 04:05 AM
The progression of tools...
1st - box wrench
2nd - vice grips
3rd - smoke wrench
-Kevin
ClayPerrine
Dec 6 2004, 07:42 AM
QUOTE(Dave_Darling @ Dec 6 2004, 12:09 AM)
--DD
Capt'n Crusty says that you will DIE because you didn't put the right screws back in the engine tin!!!!
jwalters
Dec 6 2004, 08:03 AM
The absolutely easiest and safest way of breaking the corrosion hold on any fastener is to whack it in the middle a couple of times with a hammer and drift--the shockwaves break-up all that is holding the fastener in.
I never use a impact, for over five years now--got damn tire of drilling and easy-outing, re-tapping,,etc.
In your case, your big-ass screwdiver is the drift.....good luck>>>
