Ive had fuel pump relay troubles Uno swapped for headlamp relay, cleaned the points in them etc... Last night went to start it and no 1.5sec pump sound. This morn pulled relay found pit in contact point like bad ign points. I filed it and put it back for now works great.
????Here is the question does the Red cap fuel relay have an higher amp rateing on its contacts? Whats different? Im using the black cap one people say there the same thing is this true?
????Or is my fuel pump over amping. Ive had it apart for a leak and it has alot of wear on the armature. It still hit's 70psi if you block the return line and maintains 32psi all rpm ranges.
Now for the deceleration valve. Mine is off. I don't know the exact reason for the valve but I got to thinking the way it is piped on mine it was like a T fitting from the intake to it and the MPS sensor.
????Here is the question or thought. When your running at hi rpm and have to stop the throdle bodie shuts intake vacuume at its highest and without my valve in use could this dammage the MPS where as with the valve Teed into it it would decrease the vaccume pressure on the MPS making it last longer.
???? That was my theroy now what is the deceleration valve for. Sorry bout the long post!!
