jim_hoyland
Dec 5 2004, 01:49 PM
Doe the center button on the Rear window defroster switch light up like the fog switch ?
Dec 5 2004, 01:51 PM
QUOTE(jim_hoyland @ Dec 5 2004, 11:49 AM)
yes ...
The fog lights and heated rear window actually use the same switch
only the logo in the cap is different
jim_hoyland
Dec 5 2004, 03:52 PM
Is the bulb replaceable ? Tried to pry the green botton up, but it s in there pretty good. This appears to be an original switch; mostly metal-not plastic
Rusty
Dec 6 2004, 10:32 AM
The black plastic surround should pry back a bit so you can remove the disk. Maybe you can soften it up with a heat gun.
-Lawrence
