QUOTE(Steve Snyder @ Jul 23 2013, 01:55 PM)
You will certainly need to replace your 4 cylinder tach. If you stay with the 901 tranny, your current mechanical speedo is fine. Your fuel gauge will will work assuming you are not messing with the fuel tank. Auxiliary gauges (temp, pressure, etc.) will require the correct sensors and appropriate wiring.
Sure you can save the fuel gauge but it is easier to just swap out the temp/pressure from the later motor rather than try to replace the sensors! But whatever floats your boat! I replaced the 4 gauge with a matching 6 gauge for my motor and moved the fuel gauge under the dash this way I only needed one additional wire and no senders!
You can see my 6 gauge on the left and the gas gauge under the dash!
