QUOTE(Andyrew @ Jul 23 2013, 10:18 PM)
QUOTE(7TPorsh @ Jul 23 2013, 02:44 PM)
Yup insurance methods are always questionable> Here is my friends BMW...total.
36,000 miles and super clean. New tires, shocks, etc. Valued at 22k...damage at 28k.
Manipulated industry?
Click to view attachment28K? THATS a rip off... Thats 10k in damage by the best shops... 3k in damage by a backyard shop which is most likely to buy it....
That BMW has 6K alone in deployed SRS parts, bags, clockspring, module, sensors and seatbelt pre tensioners. Another $500 in one time use deployed power distribution and battery cables. 7K in front end crash parts as everything is plastic, composite or high mpa steel. Radiator support upper is aluminum, radiator, condenser and fans are toast. Front bumper impact bar and frame rail extensions are done as well as the hood and fenders. If the frame rails are damaged behind the short stub extensions they are automatic replace items per BMW. BMW does not advocate repair on damaged structural parts. Add remove engine and transmission, suspension to access control points for fixture/ bench system at 10-14 points. Add all the little fee's like reset radio, re-initialize power windows and sunroof, clear any stored DTC codes - all required when battery power has been disconnected for 8 minutes or more, 4 wheel alignment, reset steering angle sensor, evacuate and recharge air condition. Detrim and blend the doors. Repair and refinish the windshield pillars where the hood went back and impacted. Add labor, refinishing, materials, denib and polish, relocation fee's back and forth from shop to dealer.
The items above are just a brief menu of parts and operations not getting into the really technical stuff.
Its the most over engineered brand in the world. Designed intentionally so the average Joe can't work on it.
It may not look like it in the photo but its all there. I can't even see the left side if it has damage. Rt rear wheel angle seems funky but that may just be the photo.
That car most likely went to Marcos Autobody (excellent repair shop) for inspection where it was then interned to Copart. The insurance company probably got back 6-8k in salvage value.
