I have finally tweaked and tuned my rebuild into submission or at least till I am happy with it.
With a cooler the oil is fine, and after endless messing with the MPS the power is even.
My problem is the starter is having trouble spinning the engine. I finally replaced the old optima red top, and rebuilt an old starter and put it in. No difference. The starter starts out slow, then picks up speed and then slows down. Once the engine fires it seems to do much better if say I immediately try to start it again.
I am wondering if compression might make a difference. The problem wasn't there immediately after rebuild but showed up at around 500 miles. I did raise the compression toward upper 8s to maybe 9. Of course more disastrous ideas come to mind as well. Any thoughts? Wires are tight. Thanks.
