jmargush
Jul 23 2013, 05:18 PM
I checked the TDC mark on the fan in relation to the fan housing while checking deck height on my 2056 and it is approx. 1/2" off from where actual TDC mark is.
Is this common?
Mblizzard
Jul 23 2013, 06:13 PM
Just did the same on my 2056 and they seemed to be spot on. Did you verify TDC withe the mark on the flywheel?
jmargush
Jul 23 2013, 06:24 PM
don't have the flywheel on yet.
as with everything else guess I will triple check this
TheCabinetmaker
Jul 23 2013, 06:26 PM
Fans are marked differently. The 1.8 fan could have a mark at 7 degrees
and not at tdc. 7 is only about a half inch from tdc. Is it possible you have a 1.8 fan?
I have seen fans with one mark only.
Mblizzard
Jul 23 2013, 06:35 PM
jmargush
Jul 23 2013, 06:56 PM
Definitely possible it is a 1.8 fan. In fact it probably is.
So I assume the best thing is to mark TDC on it and then also add timing marks.
TheCabinetmaker
Jul 23 2013, 07:15 PM
Do you still have the ljet?
jmargush
Jul 23 2013, 07:58 PM
I have a working L-jet on the 1.8 in the car now.
I also have the D-jet that came with the 2.0 don't know the condition of the system as it wasn't running when i bought it.
I need to get this thing in the car so I am considering putting the L-jet on it.
Any opinions or input on that?
TheCabinetmaker
Jul 23 2013, 08:50 PM
I'm a djet guy, cause that's what I know, but the ljet is supposed to be more tunable for larger displacement.
jmargush
Jul 24 2013, 05:45 AM
Guess I will have to research this more in the next few weeks
jesiv
Jul 26 2013, 04:06 PM
If you don't use the ljet I would be interested in it if it is for a 1975
Regards
James
