i installed morphenspectras Rain-Shield today!
first, let me say that this is a very nice product, well worth it's money!
second, let me say that at least for my K&N filters, the Shield needed to be about 5 mm wider. the length is ok, but it was just a tad too narrow and therefore the top of the aircleaner does not sit flush with the inside of the shield.
when i tighten the nut, the top caves in a bit, which will result in water to puddle up on top of the shield ...
i also removed the studs that usually hold the velocity stacks and replaced them with longer bolts.
reason? i didn't have velocity stacks that fit under the air-cleaner, so i bought a new set of shorter ones from CB but they ended up being too thick on the mounting plate.
not enough thread on the studs to put a nut on.
so, now i even have some velocity stacks!!
and as promised, here are the pics!
Andy
before:
with stacks:
closeup stacks:
the rainshields:
another shot of the rainshields:
and a closeup of the carb/filter/shield:
