Well, I have blown about 8-10 hours trying to figure this one out and it has me really stumped.
I was able to get it to start by rotating the dizzy about 1/3-1/2 turn counter clockwisw but it only ran for a few seconds on 3 and 4 [left some carbon on the plugs]. I did test it further by rotating the plugs in the cap but it made no difference. I changed the rotor and cap [had spares]. Does the condensor need to be grounded to the dizzy to work or is it OK that I have it hanging during test starts?
I tested the coil wire and still have not seen a spark.
I set the gap on the points 4 times. I assume it's the usual "slight drag" method?
The fuel pressure appears to be up and I can hear the fuel pump run when I turn the ignition on. I checked the routing and it is the same as the pelican diagram.
The coil gets warm and the engine does try to crank over [it sort of put, put,
puts]. Any chance this could be the coil afterall?
I checked and cleaned the F1 grounds, main grounds and tranny ground and they are all clean and secure.
I don't see any bad fuses and if they were which ones would cause this?
I'm getting sick of this.
Anyone have more basics I should run through befopre I flip?
