My fenders have been pulled on. The tight spot is obviously the rear of the
rear fenders where the body starts bending in a bit.
I built some 7.5x16 wheels with 38mm offset. To run Kumho V710 215/40/16
track tires with using -2 degrees camber it is very tight. There is no possible
way I could fit a wider tire, both inner and outer would hit. Correct offset is
about 35 to 33mm (I have assorted tiny spacers). My car is an original -6 so
the hubs may not be in exactly the same place as the -4. Also on cars of this
era there will always be differences from car to car and from left to right.
