QUOTE(scott thacher @ Dec 5 2004, 07:32 PM)
you dont really need em you can use a straight peice about an 1 1/2 inch long. the only problem with it is you need to remove injection before pulling or installing the motor. also you need to do both injectors on a side this way at the same time. just use a dremel to cut off the crimp on the stock hose.
