QUOTE(Black22 @ Jul 25 2013, 11:55 AM)
Key codes go WAY back. I just cut a key for a '38 Chevy. It had a code. PM me the code and l'll look it up. I'm a locksmith and we have software that has all of the published codes from all auto, file cabinet, etc. locks.
<SNIP>
hi Mike,
Do you (or, would you) do any 914 lock re-keying's? Or, is there a network of locksmiths from which you could recommend anyone in the San Jose CA area I might try going to.
I have a new ignition switch/ column lock to replace my worn out (& easily defeated) one. I haven't installed it yet because I wanted to re-key the door locks & front hood lever to it at same time. The good locksmith I knew near me closed his shop a while back and I don't trust this hardware with the few others I've found in the area.
If you can recommend anyone or offer any other info, I would appreciate it!
thanks -
mike
p.s. I've rekeyed house locks before, not sure how much more involved (if any) these locks might be - have not tried disassembling any of them yet.
