johnpierre
Jul 25 2013, 02:32 PM
yo everyone, went to start my car. nothing, no lights ,no oil temp lightn no radion no start... never had this problem. tried to jump start it with cables, nothing. its as if there is no battery commented. I am at work right now so I drove it this morning no problems. any ideas, I need to leave for home in 40 minutes. l
jp
mrholland2
Jul 25 2013, 02:34 PM
Ground connection? Try removing the battery entirely from the circuit and test the lights but DO NOT START. If the lights go on, the battery may be REALLY fried.
billh1963
Bad ground cable connection?
ripper911
Jul 25 2013, 02:35 PM
Check you wires on the coil.
Did you leave your ignition switch on, it could have gone bad.
All I can think of right now...
billh1963
Looks like mrholland beat me to it by a few seconds...
McMark
Jul 25 2013, 02:36 PM
Check the fuses too.
mrholland2
Jul 25 2013, 02:55 PM
Oh yah, the "big" fuse at the battery (if one has been added). That happened to me whilst driving. Turned on the lights and whoooooommmmmmm . . whole car shut off. LOL
bulitt
Jul 25 2013, 02:57 PM
Both cable connections at the battery. They may need to be cleaned if any sign of corrosion.
johnpierre
Jul 25 2013, 02:58 PM
ok going to check all those things right now. be right back...
Drums66
Jul 25 2013, 03:11 PM
....There's a BIG drain(where do I start)
some good starts above??
johnpierre
Jul 25 2013, 03:14 PM
success you all rock. I think it was the lead that comes off the pos cable from battery. it was loose, I also checked fuses all good. took off leads to coil and reattached. shit goto to and relieve baby sitter. thanks for helping a 914 brothter out...,,
ripper911
Jul 25 2013, 03:24 PM
