RFoulds
Jul 25 2013, 05:51 PM
Reassembling and as I am bolting these on, it occurs to me that they look too big. 1971 1.7 liter. Standard brakes. The protective plates behind rotor measures 13.75 inches top to bottom and rotor is only 11". Are these wrong plates or just overkill??
Spoke
Jul 25 2013, 07:42 PM
Got a pic of the plates?
RFoulds
Jul 25 2013, 08:04 PM
914Sixer
Jul 25 2013, 08:17 PM
Early struts used the backing plate off the VW 311 up to and including 72. I am seeing a banjo bolt so I am assuming it is an early strut.
RFoulds
Jul 25 2013, 08:51 PM
pelican parts has one for a 914-6 available, but not a 4. was there any difference in brake rotor size between 4 and 6, in 1971?
and yes, early strut. 1971.
Spoke
Jul 25 2013, 09:30 PM
The plates off of my 71 are 12 inches across.
Your plate doesn't look like mine.
Cap'n Krusty
Jul 25 2013, 10:22 PM
Call Bruce Stone .....................
The Cap'n
Eric_Shea
Jul 25 2013, 10:29 PM
QUOTE(RFoulds @ Jul 25 2013, 08:51 PM)
The strut is different between the two.
RFoulds
Jul 26 2013, 08:32 AM
This is the one pelican parts has for a 914-6. It looks like what I recall seeing on others as well. Anyone have ones that look like this?
RFoulds
Eric_Shea
Jul 26 2013, 12:34 PM
QUOTE(Eric_Shea @ Jul 25 2013, 10:29 PM)
Read above
RFoulds
Jul 26 2013, 01:06 PM
I did read that. Just because the strut is different, doesn't mean its not the same plate.
Eric_Shea
Jul 26 2013, 01:58 PM
OK... good luck wit dat
914werke
Jul 26 2013, 09:23 PM
You have late back plates. See attached, if you can see the stamps they say 74
Click to view attachmentThese are for the early 70-72 cars:
RFoulds
Jul 27 2013, 12:03 PM
Thanks! good info and pics.
RFoulds
Aug 3 2013, 01:30 PM
Well the 914-6 plates did not fit. I ordered them thinking it would be good to have vented plates and they might need some modding.
They ate the right diameter, and bolt pattern is only slightly different. So I slotted the bolt holes evenly on all 3 so they would still center. I also had to cut a slot through to accommodate a difference in spindle. After sloppy cuts were made I test fitted them. Although the bolted on nicely, once the hub was on it was obvious these are not right. They protrude outwardote than stock and interfere with hub and rotor. So the 914-6 spindle must be quite different. Oh well. $90 and in the trash they go. Can't restock them because I cut and bent them all sorts of ways trying to make them work.
So off to eBay to find the right ones.
914werke
Aug 4 2013, 09:20 AM
RFoulds
Aug 4 2013, 06:26 PM
QUOTE(rdauenhauer @ Aug 4 2013, 08:20 AM)
Have you got some to sell?
I dont know if they are actually available but AA lists them at less than $10 apiece. I am going to call local VW tomorrow with the part number, and see if they can get NOS or repro easily. If not, I will call AA and see what they actually have.
Spoke
Aug 4 2013, 06:40 PM
QUOTE(Cap'n Krusty @ Jul 26 2013, 12:22 AM)
The Cap'n
PM bdstone914
Bruce always seems to have parts and usually in very nice shape and good prices.
914werke
Aug 4 2013, 09:52 PM
QUOTE(RFoulds @ Aug 4 2013, 05:26 PM)
those pictured are available.
rhodyguy
Aug 5 2013, 04:34 AM
re the picture in post #4. the backing plate interferes with the hub yes? you have the backing plate on backwards. the 'cupped' edge should point to the center line of the car. the plate does not encompass the rotor.
k
RFoulds
Aug 5 2013, 09:33 AM
QUOTE(rhodyguy @ Aug 5 2013, 03:34 AM)
k
WAIT. What? the ones in post #4 were too big, by at least 2 inches. BUT, any other back plates I have seen or bolted on, have lip OVER the rotor, not away from rotor.
So which way should they be????
rhodyguy
Aug 5 2013, 09:51 AM
try reversing them.
RFoulds
Aug 8 2013, 04:19 PM
Well, color me stupid I guess. I was certain these were the wrong plates. I didnt know that anyone ever made them slanting away from the rotor! Now, I find it is not unusual.
In all the diagrams I have, and the parts lists, the plates are shown snug up to the rotor, and the lip OVER the rotor edge, as I expected. Thanks to helpful eyes on this board, the plates are back on correctly, new brake lines in, new bearings, and rebuilt calipers installed. Now just need to pump out all old fluid and bleed. but my speed bleeder tubes are cracked so off to get new ones.
that plus removing all the undercoating made for a lot of work on each corner.
rhodyguy
Aug 9 2013, 11:41 AM
easy mistake to make. beauty is you'll only make it once.
k
