Kaduku
Jul 26 2013, 10:06 PM
Okay I removed my old rear mirror using a heat gun. Came off pretty easy. My new rear mirror came with the adhesive tape. I notice one side is a dark grey. Does it matter which side I stick on the windshield.
The reason I ask is because before removing my old one, I noticed it was white.
ConeDodger
Jul 27 2013, 08:02 AM
One side sticks to the mirror base, the other to the window. Doesn't matter...
Eric_Shea
Jul 27 2013, 09:22 AM
They used to be all white. I'd imagine the new pad was made to be less intrusive meaning... Grey on the windshield side vs. a big white blotch.
Kaduku
Jul 27 2013, 10:02 AM
QUOTE(Eric_Shea @ Jul 27 2013, 08:22 AM)
Thanks all, looks like they did get smart and made a grey side, which will look alot better than that white shade that really stood out from the outside.
Kaduku
Jul 27 2013, 01:30 PM
FYI, both side were actually grey in color. It was just the protective cover that was white. Any it is great finally have a clear new mirror.
mrholland2
Jul 27 2013, 05:31 PM
when mine fell off, I used glue??
jcd914
Jul 27 2013, 05:34 PM
Since you have installed yours already this won't help you but may save someone a headache.
We had a rule in the shop I worked for and we had to use 2 people to install the mirrors. One would hold constant pressure on the outside of the windshield opposite of where the mirror went inside while the other would install the mirror.
There had been a couple instances in the past where someone pushed too hard installing the mirror and broke the windshield.
Just some thing to bear in mind.
Jim
