QUOTE(JB620 @ Jul 28 2013, 01:30 PM)
QUOTE(ripper911 @ Jul 27 2013, 07:14 PM)
If you're replacing vacuum lines you might as well buy a full set of new ones.
Just curious- are you suggesting I buy the vacuum kit from AA? At some point the PO had removed the EGR and charcoal canister. Decel valve is still there but only has the small line hooked into it. Seems more practical to buy separately given I only need 3 different sizes from what I can tell, plus the 22 mm hose which looks like doesn't come with the kit anyway. If I have extra remaining I can give it to the guy whose 914 sits along the bike path that I have been trying to encourage to get it running. No???
I can't argue with that logic. I was suggesting it because it would usually be a good time to replace them all if you're planning on doing some of them, because they are all most likely old and new ones are never a bad idea.
