Do you see much variation in head temp?
I havent hooked up the CHT yet or run the engine much since break in.
I have been using it to watch EGTs and it works fine.
I am currently trying to figure out how to read the digital data stream with a Droid tablet so I can have a generic instrument display.
Also - You can get a thermistor that works to 200C:
http://www.omega.com/Temperature/pdf/55000.pdfAnd
I thnk drilling out an old thermister and tring to glue it back together with some sort of epoxy that can transfer heat in order to get an isolated ground sensor is questionable in its final performance
It would work just fine.
That is how we install them on spacecraft.
The 4-wire measurement is more accurate than the 2-wire measurement, but the source/meter must support it.
Stu
