QUOTE(monkeyboy @ Jul 29 2013, 09:58 AM)
I am running a fully electronic ignition. Everything is set solid, and the car runs strong. It's just the tach. It's been bouncy since I had points in the car, but I will look it up.
I have had this happen to two cars. Once on my '72 914. When I changed the points and condenser, the tach steadied. (I had already changed the wires, cap and rotor.) Since you don't have points anymore...
The other time was a '76 Chevette, one of the early years of electronic ignition, (that lasted me 11 years and 188k miles with only tires, batteries, fliuds and 2 timing belts!) The local parts store suggested parking out in the country on a dark night and opening the hood. Wow! I had St Elmo's fire dancing along the plug wires and around the engine. With new plug wires the tach steadied nicely.
Your's may not be so dramatic but I'd suggest checking the wires if they aren't new.
Hope this helps somebody else if not you.
