ben*james
Jul 29 2013, 09:39 PM
I'm looking at a 914-6 matching numbers car. It's engine might be getting a little tired, ppi shows low compression on #6.
I've heard that the stock sixes leave a little something to be desired in terms of power. i could use the existing engine and have it built to a 2.2 by rothsport or go with a different more powerful engine but lose the numbers.
I am really just trying to get some ideas at this point, don't have the car, haven't struck a deal but it appears to be headed in that direction.
Also will have paint issues: another thread started on that already.
Thank you.
Eric_Shea
Jul 29 2013, 10:29 PM
Most -6 owners in your situation have the stock engine squirreled away for posterity sake and build what they want. A nice 2.4 or 2.5 with E-cams is a tremendous balance for a six.
ben*james
Jul 29 2013, 10:50 PM
QUOTE(Eric_Shea @ Jul 29 2013, 09:29 PM)
Thanks Eric. Makes sense. I guess the stupid question is do you have to do much in terms of modification to put in a different engine or is it sort of plug and play?
Jeffs9146
Jul 29 2013, 11:07 PM
QUOTE(ben*james @ Jul 29 2013, 09:50 PM)
Anything with carbs is plug and play but if you go FI you have to add FI stuff!
jeeperjohn56
Jul 30 2013, 02:40 AM
I would buy the car, take out the numbers macthing engine put it in storage and put in a 3.2 with motonics FI. then when you want to sell car you will have the origal motor. My 2cents John
jimkelly
Jul 30 2013, 05:53 AM
if money is no object - i'd rebuild the six as orig numbers car and mostly store it.
and then i'd get a nice 914-4 and put the six of you choice in it for more regular driving, a beater : )
assuming you don't have some other exotic for daily driving.
what was the quote - ball park - to have the orig six rebuilt?
stock six is 110 hp
as 3.2 is 200 hp
jim
Cairo94507
Jul 30 2013, 07:45 AM
I agree with JeeperJohn and that is what I am doing. My car is getting a stock '89 3.2 with Motronic.
In all fairness, I do not have my original block, the 914-6 case I have is from another 71 Six and is about 20 numbers off my original case. Regardless, even if it were the original case to my car, I would still box it and do the 3.2.
carr914
Jul 30 2013, 08:00 AM
Keep the Original Engine on a shelf (Whole) and put 2.2 or 2.4. Anything Bigger and you will need to be adding additional Oil Coolers
