Can someone please post pics of how they routed their "stock" throttle cable to connect to the CFR linkage?
I tried it first with the "master" pulley on the passenger side front of carb.
That worked but forced the throttle cable to make one extra 180 degree turn and was binding the cable.
And having the linkage on the front of the carbs interferes with the ignition wires and engine tins more.
So I moved the master pulley to the drivers side rear of carb.
Now the throttle cable does not reach.
However I know that others have gotten it it work like that with the stock cable.
I just need to know the "sweet spot" to drill a new hole in the engine tins.
Stu
