QUOTE(Aaron Cox @ Dec 7 2004, 10:29 AM)
QUOTE(Mueller @ Dec 7 2004, 10:27 AM)
aaron....no Vac, Jake and Brad agree on this...I like the idea of the rev limiter, worth the few extra bucks to me
Mxmark has a flawless vac unit install... says it helps mileage etc.
hmmm, non vac is cheaper
but why do i need a rev limiter again?
the Vac units do work, but for the sake of keeping things a littler simpler and less likely to fail, the mechanical unit is my choice.....
you don't "have" to run their coil, I think it just makes it easier and nicer for those that want to run everything from the same company
rev limiter is to help you (and the motor) for those times that you might be a little too busy with other things (such as driving and staying on course) so that you have better chance of not over-reving the engine...they are also nice if you had a new motor or let someone else drive the car and do not want it to go past xxxx rpm...it's easy to peg the tach when caught up in the "heat of battle"...even on the auto-x course
