QUOTE(Jeff Bowlsby @ Aug 5 2013, 03:49 PM)
I have a bag full of turnsignal/hazard flashers Len. You should make a list of things you need so I am not running the post office every other day HA!
But seriously, a relay should not buzz...maybe its some other issue? Have you cleaned all contacts, and grounds? checked the voltages at the relay base? Checked/cleaned replaced fuses?
I don't have all the grounds connected for sure. My dash is out, as are all the instruments, so I'm sure there are harness grounds not attached.
I would think (always a bad idea) that the flasher relay should work properly though. It is aftermarket - so maybe that's the deal. Wittrin or some such thing. It comes up as being for the 914 - in fact the part number is 914-618-303-11
IDK, maybe it's just me. But the thing buzzes with power on - clicks as you'd expect with blinkers and or four-ways on.
Part is available from either AA or Big Bird and they both claim it is OK with the 914.
This is sort of a re-post of one I posted a little while ago. Was directed to a thread on the Pelican board that talked about this issue, but I didn't see that it really matched my situation - or maybe it did and I didn't understand it.
I'll hold it until I get more ducks in a row.
