$3000 930 axles?
i decided to sell my porsche v8 conversion, this car runs grt, it is fully finished and turn key ready, it runs like a bat out of hell, it is a blast to drive, i only joyride it on weekends, the car is legal and has new plate tags i just put them on yesterday, all lights and gauges work as they should including the reverse light, i will try to list as much as i can, but ill probably just cover the bigger items, the front brakes are the big reds with the larger 93o full floater rotors, also new steel braided lines through out, they stop on a dime the way they should, and has the larger 19mm master, which is new along with the blue fluid also. the front suspension is 911 sc, with the aluminum cross bar,handles grt. the motor is a 350 sbc, that runs really good, low miles on motor and has alot of edelbrock pieces like the carb, intake manifold, valve covers etc, and mallory distributor, and powder coated headers with dynomax mufflers coming out the back to infinity chrome tips, they sound grt, the conversion kit is a renegade hybrids which includes a new clutch and pressure plate the biggest and the baddest, cost over 3k for that, the trans is working and shifting good, it is a 901 sideshift, that has been freshened up and has had new seals, and parts replaced, the rear axles are custom 930 full floater axles that cost over 3k also, and these will never break. the wheels are the super turbo wheels deep dish and tires in the rear are 305 35 18, thats alot of rubber back there. spent over 3k on those, the car has a 935 body kit that cost over 8k to install, the paint is nice it just has a couple of scratches not much. the rear has nice adjustable rear coilovers also, the car has carbon fiber accents and porsche name on side that look cool, the car was built with chrome , anodized, or aluminum. there is no rust anywhere, there is also new brass bushings on pedal kit area and interior is new including carpet, seats, dash, door panels, etc. it has racing seat belts and stock belts, also, the car has push start ign, so you turn toggle switch, turn key to on and then hit the push start it works grt, it also has a high output starter, the doors are shaved and they open with remote and has safety features in case you leave your keys inside, all gauges work, i sent my rpm to n hollywood speedo si it would work with mallory distr, it also has extra vdo gauges for temp, oil, and volts, has kenwood stereo with usb and headphone jack, sounds grt, the cooling system consists of a big aluminum radiator, with the continental mark v111 pull fan works grt, its hooked up to sensors on intake that turn the fan on when needed, im sure im forgetting alot of stuff but you get the idea, i also will consider trades for another cool car or project plus cash, and or let me know what you have, i like alot of stuff, for any questions you can call me or text at 818-***-**** ray,
