Full Version: New VDO Oil temp gauge not working - help
steuspeed
I bought a new VDO oil temp gauge and sending unit. I'm getting 13V power at the gauge. Light works on all three console gauges. Voltage and oil pressure gauges work fine. The sending wire Green/Black gets 7.3V on acc key turn and 8.3V car running. Any clues? confused24.gif
Edit: The old gauge never worked since I owned the car.
timothy_nd28
Disconnect the wire attaching to the temp sensor. Then measure the resistance from battery cable ground to the sensor terminal.
Go ahead and reconnect that wire back onto the sensor. Now turn your attention to that sensor wire behind the gauge cluster. Disconnect it from the gauge and measure the resistance on that wire to ground. What is the resistance of these two measurements? Do they match?
steuspeed
Should there be continuity from the sending wire at the temp sensor to the sending wire at the gauge? (Green/Black)
type47
post pix of parts or part numbers
