QUOTE(scotty boy @ Aug 12 2013, 01:26 PM)
crank mechanism may be worn. There is a replacement piece available or you may need a new mechanism. Did you take the door panel off and observe as you lower and raise the window? Some times looking behind the curtain answers alot of questions.
Yeah, I have the panel off. I had the entire assembly out before it headed off to the paint booth. What should I look for to see if it is worn? At first glace it all looks good but just not lining up properly.
