QUOTE(rgalla9146 @ Aug 13 2013, 12:03 PM)
There could be some additional difference in the flywheel / clutch package.
Question. Are those dry weights?
Some thoughts... there are a few weight differences it would be handy to know.
- 914 vs 915 clutch/flywheel packages.
- 915 clutch/flywheel package: ~23lbs with the throwout-bearing
- I don't have a 914 clutch/flywheel package to weigh. But there will be a difference between the 215mm and the 225mm packages, for those who use the latter.
- 915 Aluminum case vs Mag case (I have both, but they aren't where I can weigh them)
- 916 side shift vs mag-case 915 tail shifter, the Aluminum weight can be factored from info above.
My Guard LSD is much heavier than the open diff, but the ZF unit looks smaller than the Guard LSD. That will have to be factored into your weight differences as well.
I'm sure someone of us can make the other weights appear here!
