QUOTE(cambum4 @ Aug 15 2013, 08:28 PM)
Test #1 - remove spark plug wires and engine rpm should change. I remove #1, #2, #3 without affecting RPM - remove #4 with all the others connected - engine stops.
Test #2 - spray carb cleaner over the intake port of the carb - again the engine RPM should change - Only #4 is affected.
Firing order correct 1432
Still balancing both carbs. Heads replaced and valves are set correctly cold.
Still thinking its something stupid. It will go 55 miles and hour will one cylinder until you hit a hill of course.
If you pull all three (1,2,3) at once does it continue to run?
If you are pulling them one at a time all that proves is the cylinder is not pulling its share of the load.
It could still be burning enough fuel to not be a significant burden on the idle.
As Rich said, the balance is off.
