Always Looking
Dec 9 2004, 12:23 AM
Hi all,
I've been working (off and on) on a 72 914 since i bought it last year - $1k. I don't think it's quite ready for the run to Ruby's yet, but maybe in January. The last time this car was registered was 1982 (no back taxes, it was off the DMV computer).
Anyway, the newest problem is the po's fuel pump "relocation." He hose clamped it to some steering components beneath the car. I don't want to drive too far on this set up. I think that if i bracket it to the front trunk under the tank, that should work. Does anyone have a resource for a suitable bracket? Also, if someone would be so kind as to let me know what size FI hose(s) i'll need, i'd appreciate it. I figure ten feet of to line and ten feet of return line should do it.
Thanks for any info.
aveale
Dec 9 2004, 09:55 AM
ah fuel pump fun........
i pers. feel that you can put the pump anywhere where it is protected from heat and gunk.
i can't see why the steering arrangement would not work. as long as it is not getting mangled in there.
fuel hose sizes are funny. i believe it is a 7 mm hose to the injectors and a 9mm hose from the tank to the pump. so you may have to use a 1/4 inch ID and 3/8 inch ID hose and some inventive connectors to get things to attach accordingly.
have fun.
T
lapuwali
Dec 9 2004, 12:06 PM
Mouting the fuel pump near the rack is commonly done. As long as it's not in danger of being hit by a tie rod, there shouldn't be any problem. You should also have the undertray in place, which should provide plenty of protection for the pump (as well as the steering, which is why it's there). If you're concerned about the hose clamps, then by all means, make a bracket. All you need is some sheet steel, some tin snips, and a bench vice. Any small bracket like that can be fabricated pretty easily.
JoeSharpOld
Dec 9 2004, 06:21 PM
Al: Welcome to the Garage.
What they said. I'v got a couple of porject cars going on here. If there is something you need to look at, or just come by and talk teeners, I'm in the emer. contacts.
Joe
Always Looking
Dec 10 2004, 12:10 AM
Alright, Thanks for the info. I may take you up on the project inspection after the holidays.
Aaron Cox
Dec 10 2004, 12:13 AM
I have a very bitchin fule pump install...i have yet to take pics of it to show people
DUH!
im not too far from you....
if you come to ruby's (in anything that has 4 wheels) you can take a look for yourself.
hope to see you there
