QUOTE(Amenson @ Oct 20 2017, 10:12 AM)
Purpose of the shroud is to increasing radiator utilization while stationary or at low speeds by allowing the fan to draw air through the entire radiator instead of just the area covered by the fan. Certainly, at speeds higher than what the fan can create, the shroud will limit the flow to what is capable of passing through the fan.
That said, I have yet to experience a shrouded radiator that cools while stationary, not cooling at high speeds. I have experienced an un-shrouded radiator not cooling.
I've actually had they very problem before with a shroud that sealed too well and excessive pressure drop through the fan limited air flow. It was pretty neat, we put yarn on the inlet duct and actually saw reversion as vehicle speeds increased (didn't happen at the magical 25 mph number though
). Like you said, not well enough shrouded it usually the issue and flaps are easy. Just though I'd put this anecdote here since it actually does happen. OTOH, that was on a racecar, street cars just don't have the high-speed, high engine load duty cycles so they're likely a bit more forgiving.
In any case, it looks great! The mustang cap looks nice too-definitely going to steal that one!
