Been a while since an update...havn't fallen off the earth, just not very active online.
I did take a couple of weeks of garage time to make the wife happy and insulate the shop and put up wall covering. I posted a picture on the Porsti build thread.
As for progress on Grey, knocking stuff off the list toward road worthyness.
A few photogenic updates:
Finally got the auxilary fuse/relay box to fit properly. Required quite a bit of reshaping, probably would have been quicker to cut the area out and weld in a flat section pre-cutout for the box. Still needs to be painted.
Click to view attachmentClick to view attachmentAlso got the IC pump mounted and the overflow and IC reservoir modified/mounted.
The pump sort of interfered with the bottom battery tray mount that was unnecessary and quite ugly...so I removed it. This opened a huge can of worms due to the less than stellar hell hole repair. For a couple of hours I was seriously contemplating redoing the entire hell hole repair. More than a little cutting/welding/grinding later and the area is presentable.
I decided to attach the expansion tank to the IC reservoir which made it impossible to use the inlet I cut it out and plugged the opening (pic pre welding). I also added spacers to the back of the reservoir because during one of Tom's visits he pointed out that it is a bit tight to get to the cap. Still not super convenient but better.
Click to view attachmentMade some plates to attach the two reservoirs. The expansion tank was chromed so I sandblasted it to remove the bulk of it. Turned up the cleaning a bit on the TIG and it welded pretty well.
Click to view attachmentClick to view attachment I still need to add the inlet bung and will probably put a braket at the bottom of the expansion tank.
Click to view attachmentHappy New Year
Scott
