I am on the cusp of finally putting some proper rubber under the PorSTI so I took the opportunity to work on the suspension on Grey for a bit to get a feel of how much space is available under the flares.
First step was to get the car down to ride height.
I pulled the springs in the rear and found that they did not sit in the spring cups very well. The OD is ~5mm larger than what the upper cups want to hold.
Click to view attachmentThe lower spring perch works but the spring is pretty loose. Also, there was an odd spacer under it sitting on the clip that locks in the groove on the shock body.
Click to view attachmentAnyone have any thoughts?
In the front I needed to clock the torsion bars by one spline. The Driver side did not want to come out of the control arm. I got it out and found why it was being difficult. The front of the control arm was open. Looks like the end cap was pushed out at some point.
Click to view attachmentLooks like it could just be a welch plug. Is this part available?
Working off the lift with no rear springs makes it very easy to play with ride height. I think it looks pretty good right there.
Click to view attachmentDriver side is rubbing on the inside and the passenger is rubbing on the fender lip but they will fit. Will trim the fender lip to give some additional room and will probably need to adjust the spacer's once it is aligned.
Cheers,
Scott
